Old 03-26-2009, 02:12 PM   #1
Ron Finney
Ron Finney's Avatar
Default Re: 1/4 mile...RPMs??? HELP
Originally Posted by watsongarage View Post
I have an 1/8 mile bracket car. It's a '67 camaro, 2700 lbs. wet, small block , powerglide , 14/32 tires with a 538 gear. Does anybody know what my RPMs might be running a 1/4 mile?
If you know what your 1/8mile ET and MPH is you can determine your approximate 1/4 mile ET and MPH. One quick way to estimate is to look at the index system for the NHRA classes. Once you have an approximate 1/4mi. MPH use the following formula. It will be failry close, will vary some depending on the slippage in your convertor.
rpm = (mph x gear ratio x 336) / tire daimeter.
Hope this helps....
Ron
33 S/C
Ron Finney 396V S/C
Ron Finney is offline   Reply With Quote
Old 03-26-2009, 06:00 PM   #2
MudWild680
Send a message via AIM to MudWild680
Default Re: 1/8th mile car running a 1/4th mile...RPMs???
This wont answer your question i dont think..
but another way to find out what your car will run in the 1/4 is to multiply your 1/8 mile time by 1.55
MudWild680 is offline   Reply With Quote
Old 04-07-2009, 12:15 PM   #3
Dave Goob Cook
Dave Goob Cook's Avatar
I only gain 400-500 RPM's out the back in the 1/4 over what I'm turning at the 660' mark, but my car is heavier, and slower accelerating than yours, I'm sure.
"Despite the high cost of living, it remains popular."
Dave Cook
NHRA N375
Dave Goob Cook is offline   Reply With Quote
