Old 05-20-2009, 08:36 PM   #1
Real Racer
Default Re: '66 Dodge D-Dart at Mecum auction
Originally Posted by njk53 View Post
The air cleaner doesn't look correct. The way the fuel line is routed on the inner fender panel doesn't look right. Also, it looks like it has the small rear axle assembly by the looks of the small bolt pattern on the wheels. I had a 64 1/2 Barracuda, and 2 65 Formula S cars at one time or another and as I recall, you couldn't get a ring and pinion over a 3:23 in it because the case was so small 7 1/4 I think. Does anyone know the gear ratio the D cars came with?
Chrysler offered a 3.91 for the 7.25 rear axle.
I had several 65 and 66 273 Formula S Barracuda's and installed them in every one several times.
Untill I got tired of breaking them and finally put a 8.75 from a wrecked 67 383 Dart.
Also all A bodies from 64 thru 69 had 4 inch bolt circle hubs.
Real Racer is offline   Reply With Quote
