Old 07-03-2009, 10:55 AM   #1
pro70z28
Default Re: Billet Aluminum Dash Bezel
Well, it's another small step but I figured I better dust this thread off. The mold I made for the glove box way back when finally produced a part.
I cut the bottom of the glove box to the contour of the intercooler and glassed it in place.
Flipped it over, cleaned up all the overlaps & danglin' tabs and gave it a couple layers of cloth to hold it together.
Got it roughed in to a 100 grit state & gave it a light coat of primer
I think I'm going to stop here. I'll do the finish work later when I'm ready for final paint. This little project took months (a few minutes here and there). I think I'll work on the engine compartment for my next project. I have a header tube clearance problem to address and then I'll start reconstruction of the firewall. Hopefully I can pick up the pace some on that deal.....
The more I LQQK at the intercooler in this pic. I'm thinking I might change the outlet tube connection to a bolt together joint instead of the hose clamp set-up. I can see that thing blowing off taking the dash with it. That might be bad for me knee & ears too. :-[
pro70z28 is offline   Reply With Quote
Old 07-07-2009, 05:52 AM   #2
pro70z28
So, I had some time this weekend & I decided I'd get the hose & clamp set-up replaced. I pulled out the old slab of aluminum and started whittlin' away.
Flipped one over & cut an o-ring groove
cleaned them up on the lathe & cut the mating surfaces for a nice air tight fit.
Finished and ready to install.
Old 07-07-2009, 05:56 AM   #3
pro70z28
My aluminum welding skills aren't the best, but I got 'em melted together.
Intercooler side with o-ring
all bolted together and back in the caah.
dash cover back in. No more hose & clamps. I feel safer with this set-up by my shin. I've seen some ugly footage of those clamps letting go.
That's what I did this weekend.
Old 07-12-2009, 06:48 PM   #4
Bob Pagano
Bob Pagano's Avatar
Liked 16 Times in 11 Posts
You have a real talent, you should pursue it in some way. your having fun doing it. Why not make $$ while doing it. Good luck with the rest of your project. Best Regards
Bob Pagano A/SA
Old 07-20-2009, 10:53 PM   #5
pro70z28
Thanks Bob.
I have a one man sign shop that keeps me pretty busy & is something I like to do also.
The fab work is a nice change of pace.*Something to do to relax on those rare occasions when I have nothing to do.
Old 08-30-2009, 07:12 PM   #6
pro70z28
I had a couple hours yesterday afternoon & a couple more this afternoon, so I thought I'd get organized for the upcoming "Z" firewall build. I've got some sheet metal tools that have been under the bench for a good long while now. So, I chopped up an old attachment I had for my first track loader that was just collecting dust in the corner. It had some slip tubes on it (like a receiver for the hitch). I used some angle iron I had in the shed and made this deal up. I put it on an outside corner of the shop so I'd have plenty of workin' room.
å
I bought a stretcher/shrinker at a car show a couple years ago. No mount so it hasn't been used yet.
Harbor Freight Planishing hammer. Might call it new old stock. I've had it for a long time too, but never used it.
I've used the bead roller a couple times. Clamped it in the band saw when I DID use it.
I'm wondering about a wing (table top) on each side of the bead roller to help feed the stock through? or maybe it would just get in the way? Any thoughts?
I still plan to make an attachment to hold the bench vise, and one for a small welding table. I'm gettin' tired of saw horses......... ops:
that's what I've been up to this weekend.
Old 09-01-2009, 08:17 PM   #7
pro70z28
I welded up the welding table tonight. I cut the supplies kinda' close. I have 1/2 pc. of filler rod left, 20 PSI of argon in the second tank & the 20''x20'' table top was the biggest pc. I could get out of what's left of a 4'x4'x3/16'' sheet of steel.
Bracing under the table. Gettin' low on that stuff too, but I got er' done.
Old 09-05-2009, 10:15 PM   #8
pro70z28
Worked on the bead roller today. I got rid of the hand crank and put a bicycle wheel in its place. Local bike shop gave it to me, it's a little bent, but it works for this deal. I figured the bigger the wheel the better control. I had to try it out, works a whole lot better now. . I made an aluminum table for the exit side. Loosen 1 thumb screw at the bottom and it lifts off a couple pins on the top. I scribed some lines every 2" as guides. no fence yet. I think I'll use it this way first and add a fence later.
Got the Vice mount done. I made a knee brace for those times when I feel the need to beat on the vise. Same brace will work on all the attachments.
....and I got the rack finished up tonight. Everything in easy reach, tucked away behind the door. Oh, I bent up some scrap sign aluminum also, to protect the wall.
I think I'm ready to start on the "Z" firewall now. I have to put a quick disconnect in the planishing hammer air line so I don't have to drag the foot pedal around. It's a pain in the hose this way.
