Old 07-20-2009, 09:00 PM   #1
Ron Finney
Ron Finney's Avatar
Default Re: Throttle stop help
Good Advice you need the weather....but not totally convinced you can't do it with a hand held. Maybe 'cause that's what I use (cheap). But then again, I am the only guy in Super Comp that still shifts his car by hand (stubborn). Definitely doesn't hurt to get the best data you can... If bucks aren't an issue go with the good stuff suggested, 'cause even the handhelds have a learning curve.
Ron & Meridee
33 S/C
'09 Jeg's Allstar
Ron Finney 396V S/C
Ron Finney is offline   Reply With Quote
Old 07-25-2009, 09:31 AM   #2
BIZMANRACING
BIZMANRACING's Avatar
how does all this advise apply if you run alochol? my car is about mid 9's all-out at 140. last time i ran s/st was about 3 or 4 years ago. i plan on getting back in. back then i was on gas.
S/ST 1739
Carlos Mendes
BIZMANRACING is offline   Reply With Quote
