Old 08-06-2009, 05:31 PM   #1
GTO/GN
GTO/GN's Avatar
Default Re: "G" Body suspention tips ?
I have been using the the 8.5 ten bolt in my Grand National. I put Moser 30 spline axles, Eaton posi and c-clip eliminators. Using the stock 3.42 ring and pinoin and it has held up to countless 25 lbs of boost trans brake leaves and it has gone 9.64 @ 140.11...
GTO/GN is offline   Reply With Quote
Old 08-07-2009, 12:40 AM   #2
CJohnson
CJohnson's Avatar
Ya the 8.5's are stronger than some people give them credit for, my old man runs one in his racecar with stock 28 spline axels auburn posi and 3.91's
CJohnson is offline   Reply With Quote
Old 08-07-2009, 08:11 AM   #3
BRUCE COMPTON
BRUCE COMPTON's Avatar
Craig,
We have built several G body cars including a stock eliminator Malibu wagon, If you want or can give
me a call and I will tell you about the stuff we have found. Most of the tips you have gotten are good
but there is more. Bruce Compton Boise,Idaho 208-362-3570
BRUCE COMPTON is offline   Reply With Quote
Old 09-25-2009, 10:11 AM   #4
Redlight
I have gone threw some changes on my Gbody (bracket not stock) at one point ran this:
Front: Stock SBC spring with 1 coil removed, loose front suspension with poly bushings,lower arms "level" with ground,5 inches travel, cheap 3 way shocks set driverside 70/30 pass.side 90/10
Rear: Eibach lowering springs,boxed lowers with poly, adjustible uppers with TRZ joints in the 12 bolt,single adjustible shocks, single air bag (7 to15#), -2 pinion angle. 30x9 radial slick
Car would leave hard 1.44 to 1.46 but twisted bad and was a handfull down track.
After many upgrades, double adjustible shocks all around, HR&stuff bar,no air bag.
The car leaves straight and now can be driven down track with one hand.
Since someone mentioned the bracing ,which these car NEED, here you go.
I am new to the "stock" deal so I don't know how much of this is "legal"
I made this up for another board.
GM body braces, forgot to make a legend on this one:
Now the tuff one to do, overlay:
Hope you enjoy."
Redlight is offline   Reply With Quote
Old 09-27-2009, 04:53 PM   #5
holben
Liked 2 Times in 1 Post
Looks like they've got you on the right track. You will most definitely want a rear anti-sway bar to counter the body roll that is increased when you raise the upper control arm rear mounting point (center of the car). The 8.5" 10-bolt that was made for these cars in the mid-eighties by Buick is a very strong piece with a spool and axles. Since you already have the 12 bolt I'll stop right there.
Good luck with your project.
Don
holben is offline   Reply With Quote
Old 09-27-2009, 06:22 PM   #6
Curt Rees
Liked 250 Times in 51 Posts
I just added a sway bar. I have a 12 bolt with 6:14 gears. The car leaves nice and level now (see picture in Pierre National Open pics) and picked up up a 10th in the 60' time. I run Hoosier 9/30 radial tires.
I run 3 way shocks in the rear set at 50/50 and 70/30. I have Jeg's adustable upper control arms with AFCO bushing. I run 3 way shocks in the front set at 90/10, Moroso springs. I am going to change the front control arm bushings.
#5457
Curt Rees
Curt Rees 5457 SS
Curt Rees is offline   Reply With Quote
