#1 | |
I'm open to any other suggestions ....
Dave Steltz 135G SG/SP/SST BIAECH Racing Team |
Liked 361 Times in 104 Posts
Dave, is it a aluminum valve body?
If so read the other transbrake thread. This issue is why I do not use the alum brake on any trans I build for myself or a customer. Hope this helps. Rick |
Rick, nope , steel valvebody...
Liked 551 Times in 215 Posts
Dave, like I said the solinoid only energizes to apply the brake. Once power is removed from the solinoid it de-energizes and the pressure in the trans. drives the valve and the solinoid back. There is no spring in there like the old ones. If the solinoid is free to move without any binding there is nothing it can do to slow up your RT's. Maybe you blinked or your getting feeble.....
#5 | |
Gary Federico S/St, S/G 1814 |
Dave, I do not have a good answer for you on this one.
Usually if a solenoid goes bad the brake will not hold or holds intermittenly. Heat is a killer of a lot of things on a trans. I always suggest running as big a trans cooler as possible and a deep pan if possible. That helps with the temp issues. That is about all I can come up with at this time. Hope this helps. Rick |
#7 | |
Some one else posted a reply about "getting long in the tooth" ...I think he used to race but I cant really remember when, so I'm not gonna comment on that one....
Banned
I think I remember that guy, I also think he was div. 1 champ , but it's been so long since I seen him at the track he may have retired. He looked preetty old to me. |
No one has seen him at the 8.50 races either...hmmmm...maybe he IS retired....
Liked 192 Times in 83 Posts
Hey Dave.... I had a similar problem some years back.... intermittent release.... my lights were worse than yours.... went through everything and found nothing.... then one night at Island, in the semi's, I let go of the button and the car sat for like 15 seconds.... went home, got a new button, problem solved.... check it out if you haven't already.....
