#21 | |
It will actually be better for me. It will give me more time.
Art Leong 2095 SS |
#22 |
Liked 11 Times in 4 Posts
I will say i learned something new today also, i am not sure i would call it courtesy staging?
larry dowty 6388 SS |
#23 |
Liked 1,847 Times in 418 Posts
I suppose the "courtesy" comes from the first person not lighting both lights at once.
Alan Roehrich 212A G/S |
#24 |
Just wondering(sounds like Burke of DRO) has one of the major timing systems ever fix the bug in their autostart software that would allow a racer to trick the autostart timer to be activated? Some multi national event winners learned that if they knew their opponet would try to stage second, they could briefly stage after both cars had prestaged. By bliping the stage light the timer for timing out was started but you had to confident the other guy was a diehard go in second racer. With the count down in motion a racer could go in after waiting a few seconds and the other racer got what was left of the count down of the autostart software. This technique would be more effective in the super classes where a pro tree was used but could be use to throw off slower classes going first by distracting them with a quick tree where handicaps are used. This may be just BS I was told to see how gullible I was, but does make for some interesting questions. Food for thought.
#25 | |
Michael Pliska 643 S/G |
#26 | |
You were probably DQ'd because of the deepstage. But while you did try to back up and fix it, that would also DQ you. The rulebook states that your last movement into the stage beams must be a FORWARD motion. I believe this is to prevent people from going across the beams and backing up to the point where they are just barely deep staged. I ASSUME, but do not know for sure, that that rule was implemented during the early years of super class racing.
2002 Division 6 High School Champion 2007 Division 6 Pro Champion 2007 Division 6 National Open Series Stock/Super Stock Champion |
#27 | |
I just didn't understand the rules. it was my fault. It won't happen to me again.
Art Leong 2095 SS |
#28 |
Liked 282 Times in 103 Posts
Getting back to the Driver A and Driver B scenario,the track gave the rerun to Driver B.Go figure.
#29 |
Bimbo Jones, I had a situation somewhat like you talked about at Cordova this year at one of the Heartland races. Both cars where stick cars,and both are long time class act racers, so no one was trying to pull anything. Car A and B prestage, car A goes in, Car B waits a second or two, Car A backs out, car B goes in , before car A can get back in staged the system times out, and car A has his light go red.
Michael Pliska, at least with Compulink a car can just blink the staged bulb, and the system will not start, most systems you must be in a set amount of time, half a second say, for the time out timer to begin. 442 OLDS , do not know all the circumstances, starters sometimes have great discretion, but if he prestaged and you where staged, I do not see a rerun being in order., Hope this helps. Jimmy D. Hyink |
#30 | |
