Old 09-16-2009, 08:36 AM   #9
buzzinhalfdozen
Liked 11 Times in 8 Posts
Default Re: 7AL or Digital?
Originally Posted by craig addis View Post
Thanks for the info. I will check into the crank trigger. You never knew when the box would lock up. Did it to me friday fifth round at ten grand nationals. Is that crank trigger a three wire unit?
Craig, the sheilded pickup is not a 3 wire it has a shield wire wrapped around it and a grounding lug at the motor end, obviously to ground to motor. This prevents"noise" from entering the pickup wires. Joe
Joe Buchanan SS/BX 3117
