Old 09-21-2009, 03:13 PM   #1
Tom Goldman
Tom Goldman's Avatar
Liked 883 Times in 237 Posts
Default Re: Master cylinder help
Originally Posted by Ricky Clark View Post
Anyone tell me what type of master cylinder is best to use on GM stocker? Pedal hard as a rock looking for a little info Thanks
A little more info on the car would help, but the first thing I would recommend doing is checking the pedal ratio. ........This is especially critical when converting from power to manual brakes. ......It is especially a problem on late F bodies , where the stock pedal ratio is only about 4 to 1. ........ You need a pedal ratio of about 6, 61/2 to 1 to generate enough pressure for a typical brake system.. .......I'v always used te Strange /Mopar type cylinder with a 1 3/16" bore. .... Quay , FJ Smith and others make an adapter plate to adapt to the existing GM mount ,and it also offsets the center upward to locate the pushrod closer to the correct point on the pedal. .........Don't forget to install a stop bolt to prevent the pushrod from coming out of the master cyl., A few of our forum members can tell you stories about unplanned trips to the gravel pit when that happens!. ........Tom
