Old 09-26-2009, 03:20 PM   #19
Rich Biebel
Rich Biebel's Avatar
Liked 557 Times in 217 Posts
Default Re: 1150 dominator Questions
A 9375 is a good 1050 to look for and try.....They run well and jetting should be 92's as a baseline. Anywhere from 88 to 94 is a normal jetting range on those. Holley's generally do the Holley "gurggle" and it is pretty normal.....If it holds a steady rpm without sinking it is ok....If it loses rpm after it runs a while and goes back up after you rev it a few times...it's too rich...fixing that is not always just a matter of an adjustment.......Too big a carb or cam or both often slows a car down......
Rich Biebel
S/C 1479
Stock 147R
