Old 11-02-2009, 01:29 PM   #1
Lou SG2340
Default Re: Air vs. Electric #1 stop?
I like air vs elec. You can set the closing & opening rate. You can't do that with elec. I don't let the pressure in the bottle get below 500psi.
Lou SG2340 is offline   Reply With Quote
Old 11-02-2009, 04:02 PM   #2
s/gfairlane
thanks guys, i appreciate it. i was hoping to get some more opinions.
s/gfairlane is offline   Reply With Quote
Old 11-03-2009, 06:42 AM   #3
Bob Verwold
Bob Verwold's Avatar
Like Lou, I also use air but I also have an air shifter..........And carry an extra air bottle in the trailer.
Bob Verwold is offline   Reply With Quote
Old 11-03-2009, 02:31 PM   #4
s/gfairlane
Thanks for the reply Bob.
Old 11-03-2009, 05:50 PM   #5
Bob Verwold
I also should have said that I don't run an alternator, so I try to have as little of a draw on the battery's as possible.
Old 11-14-2009, 07:59 PM   #6
been200mph
Electric is fine in a heavier/lower powered setup. Air allows you to not unload the chassis when the stop closes or spin when it opens up. Gary Heuer did the first air stop for me back in 91. I'd run SC at Memphis and had a spin issue when the stop opened right as it was near a bump on the track. We came home with a CO2 bottle, regulator, and the rest is history as we changed from electric to air. If you have questions just call Gary direct at 319-277-5290. He's a wealth of information. Tell him I sent you.
Steve Oldani
been200mph is offline   Reply With Quote
Old 11-16-2009, 10:53 AM   #7
Chris Williams
Chris Williams's Avatar
If you look around at all the most competitive Super class cars, they all use air. That should say something...
Chris Williams 6304 SC, TD, ET
Chris Williams is offline   Reply With Quote
