Liked 10 Times in 10 Posts
Alan,
The D-Dart mysteries makes your head spin. Kind of like a 16 year-old virgin on a carousel, at a prison rodeo. The D-Dart carb spacer part #2863052 (.938 thickness). The intake (free-flowing/modified intake) may have been an earlier version, similar to, Vanke's intake modifications on the 67' R/O and W/O Hemi Super/Stock manifolds. One things for sure, all small-block 273 Mopar guys were cutting out the center shut-out areas on the intakes, for increased air-flow at top-end, back then. As well as putting on a 15/16"-thick heat-risers between the carb. and intake, to prevent vapor lock. Paul (I'm not sure, but the Hurst # may start with a DP-.... ??? |
#2 | |
Liked 4 Times in 4 Posts
Thanks, JimR
Jim Rountree |
#3 | |
You come up with some great quote.........................Lov'em The spacer that came on the D/Darts was a 1/2" aluminum plate. It was an in-house, crudely machined part. Not sure what the over-the-counter part (2863052 - carb flange) dimensions are. But, the price was $18.95. I popped open the throttle plates on "The Pollitician" a little while ago. It has the 4 holes in the intake. I'm sure if it ment picking up a few ponies, Ted Spehar or Al Adam would have cut out the center. Sent out a couple of emails looking for info on the Hurst shifter. In the SS&DI article on "The Pollitician", there's a shot of the interior with a thin, round handled Hurst shifter. It might be the one that your talking about. It's also seen on the D/Dart campaigned by Coronet Dodge. Alan |
Alan,
On the Hurst shifter. Still tracking info. Stuck on part #3916790, But that comes up for a 66'-69' B-Body. I wonder if that was also used for the D-Dart. It came through with a long-handle shifter (16", I think). Now the 65' Darts (273/235HP Commando's) came through with the Hurst shifter as standard equipment. Wondering, if they utilized that shifter with the D-Dart?? As I said earlier, the Inland shifter (for 66', 67' and early 68') Mopars had to be installed in the cars for safety reasons (positive reverse lock-out mechanism). After they got to the dealers, than the options were installed (ie; Doug Headers). As for the intake, I'm wondering if there were (2) different versions. The 66' 273 marine engines and early "LA" 318 marine engines had a modified intake with the center shut-out area removed. I know that for a fact, because at my fathers engine shop we had several 273/318 marine engines come in with factory installed Holley carbs on the intake, not sure of cfm size, maybe 600's or 650's. The adapters were aluminum, and had 4-tapered holes (funnel-type), mounted on the open-throat intake. paul |
