Liked 64 Times in 25 Posts
We use a small bottle for the stop only (electric shift) and we get close to a full season, we carry a spare and always shut the bottle off after a run.
Carl Juliano TS 1275 John Juliano SG 151 Carl Sr. |
One thing to keep in mind about filling a smaller bottle (10oz) from a bigger one (e.g. 5 or 10 lbs) is that the larger bottle will lose pressure over time. This means the smaller bottle won't get to the full desired pressure. Most people think you should have at least 500lbs of pressure in the bottle, and run the valves at 100+. A 1/2 - 3/4ths used bottle may not have that kind of pressure, even though it may well have a bunch of CO2 left.
At something like $25-35 a tank for an exchange at a welding supply store, I swap the bigger bottle every season, regardless of how much is left in it. Cheap insurance to having more than enough pressure.
Chris Williams 6304 SC, TD, ET |
I struggled with finding someone to fill my small bottle.I was told that paint ball guys could do it and they cant, they run different fittings.Then the fire extinguisher guys, No luck. Will a Nitros Pump work? Where would a guy get the pieces to build a transfer hose? Or is there one available from somewhere? I do live way up in Northern BC Canada so we may just be out of the loop. Im not sure..hahaha
Welding supply places:
Here's one from Airgas: http://www.airgas.com/browse/product...&recIds=191563 Beer home brewers: Here's one place: http://kegman.net/refiller.html#5057
The Paint ball store in my area has a adapter to fill the 10 0z bottles maybe you should talk with the manager and see if you could get an adapter to there fittings. The store that I use has about 25 to 30 racer that fill at his store and the it is under $3.00 to fill a 10oz bottle.
