Old 12-31-2009, 01:31 PM   #1
luckydog
luckydog's Avatar
Default Re: Looking for some tire help
My opinion: you will get many more runs out of a set of Mickeys. I had a set of Goodyears on my car once and wore them out in 60 passes. Put a set of Mickeys on it and i can go 150 no problem. Also, with Mickeys, you don't need NEAR as big a burnout. (this is just from my experiance). I have a 3200lb 92 Camaro that I've found 10 lbs works best with. Last year switched from regular to stiff sidewall and was very impressed with the results!! Much more consistent 60'!! Give Mickey Thompson a try, you won't regret it.
Damien Hazelton
Lucky Dog Racing
luckydog is offline   Reply With Quote
