#31 |
Liked 293 Times in 65 Posts
I don't have pics, but I'll try and take some this weekend of the assembled engine. I ended up using steel shim head gaskets from Mr. Gasket...I also learned the hard way that ALL Milodon pans use the later model "thick" front seal. I put it together the first time with the 1-pc. blue oil pan gasket (best invention in gaskets) that had the thin front section. Then I noticed that I could still see inside the pan after it was all torqued down! Good thing I saw it...that would've been a mess. Anyhow, next up is water pump, distributor, carburetor and etc. In the next couple weeks I'm planning on buying a repop passenger door and heading down to help out with sanding. Progress! Anyone looking to throw out the following items, contact me before heading to the dumpster: Quicktime bell w/ window, Long shifter, Advanced clutch, 66 Nova headlight bezels, SS rocker mouldings, SS decklid moulding, fast Quadrajet, and, and, and...
#32 |
Liked 93 Times in 52 Posts
Where is the car at?
#33 |
#34 |
Liked 5 Times in 5 Posts
Great project Paul,,,,makes me miss my 66 I had 30 years ago,,,,maybe I should look for another one. You mentioned in your original post "other boards I frequent" where car builds are shown. If you don't mind,,what sites would those be? I'm sure lots of us would like to check them out. Thanks for any info,,,,,,,,,,,,,,Danny Durham
#35 | |
Lots of projects/builds at www.camaros.net , if you go there just click on the 'forums' button and then go into the body shop forum....there are 4-5 complete builds going on there now of first generation camaros. Chevelles.com is another site with builds. |
#36 |
Thanks Michael,,,,,,,,,,,I appreciate the tip.
Danny Durham |
#37 |
![]() You're welcome Danny. If you go into the Body Shop forum at Team Camaro (camaros.net) and do a thread search going back about 75 days you will find about 5 current builds going on. Here is mine, a '68 RS that I cut apart to rebuild it into an RS/SS street/strip car. It has been a pile of work, and I still have a long way to go. Once I get this one done in the spring or early summer I will get my project SSer (69 camaro) under way and then I have a '69 X-55 (SS-350 4 speed AC Hugger orange) project lined up. Most of the metal work is complete on both the '69s, I will probably post them at TC as well. BTW-you can search around on the main page at Team Camaro and you will find 'sister' sites for chevelles, novas, and other Chevrolet muscle car forums. The '68 street/strip build- http://www.camaros.net/forums/showthread.php?t=164396 |
#38 | |
#39 |
Thanks also, Paul. I've been to jalopyjournal before,,,theres a lot of stuff on there, not to mention a crazy photo thread. You could spend all day on that one. Take care and good luck on your project,,I know you'll keep us updated as time goes along.
Danny Durham |
#40 |
Just a little new progress to report this time...last weekend I went to Macon and helped with the car a bit. I scuffed the dash and other interior sheet metal so it can be primed. Then I hit the rollbar with some 150 to remove the surface rust and mill scale, and shot a coat of etching primer on it. Meanwhile, Wayne worked on the passenger side quarter, which is just about ready for primer. In the pics it looks like a ton of filler, but it's mainly a skim coat.
