Old 04-25-2010, 05:52 PM   #1
Tony Curcio
Tony Curcio's Avatar
Liked 4 Times in 1 Post
Default Re: Ignition Retard
Before there were programmable boxes, the NASCAR engine builders would bend the tangs on the distributor reluctor for the cylinders they wanted to retard or advance, then check the results by putting a timimg light on each cylinder. I guess it was trial and error until they got the right amount of change.
Tony Curcio 1860 STK
Tony Curcio is offline   Reply With Quote
Old 04-25-2010, 06:11 PM   #2
astikhossw
astikhossw's Avatar
Liked 20 Times in 9 Posts
Why not just put a hotter or colder plug in that cylinder.
astikhossw is offline   Reply With Quote
Old 04-26-2010, 06:19 AM   #3
sg1586
Poor flow??? What cyd's and whats the firing order Ford,Chevy??Are you using a carb?? If it's lean in those cyds would more fuel help?? This can be done..
sg1586 is offline   Reply With Quote
Old 04-26-2010, 04:58 PM   #4
6bblflash
440 Mopar,Edelbrock 6bbl intake. Of course Holley 2300 carbs.
1-8-4-3-6-5-7-2
Only #4 breaks the plug.
6bblflash is offline   Reply With Quote
Old 05-03-2010, 08:07 AM   #5
Adger Smith
Liked 880 Times in 311 Posts
Put a colder, non extended tip plug in it.
If you are using a stock dist. I think PPPC sells a dist. relucter (SP) that has bendable legs.
Adger Smith (Former SS)
Old 09-15-2010, 04:08 PM   #6
Tom Simon
It's been 6-7 years since I read the sale literature when it first came out, but I am 95% certain I remember MSD's Digital 7 does exactly what you are asking for... individual advance/retard by individual cylinder.
Tom Simon is offline   Reply With Quote
