Old 05-17-2010, 05:40 PM   #5
R&S Motorsports
Default Re: Any tips for shifting by time instead of rpm?
Having shifted on time for years I can tell you your car will most likley need to shift somewhere between 2.1-2.7 sec depending on rear end gear, trans ratio, hp etc. If you have a computer or a playback tach it would make much easier to pick your exact number, otherwise start on the low end and work your way up to your desired RPM. Good Luck
R&S Motorsports is offline   Reply With Quote
