Old 07-13-2010, 06:18 PM   #1
ken robinson
Liked 224 Times in 87 Posts
Default Re: Is my brake porportioning valve bad
Ya thats what I've been doing just to get by . But it can push you wright out of the burn out and miss putting enought heat in the slicks . I dont think my cars got a porportion valve , I think its just a pressure switch that lights the dash light .
Old 07-13-2010, 06:38 PM   #2
Tony Curcio
Tony Curcio's Avatar
Liked 4 Times in 1 Post
Your last comment is correct- drums on all four won't need a proportioning valve. Try adjusting the shoes to the point they start to drag.
Tony Curcio 1860 STK
Tony Curcio is offline   Reply With Quote
Old 07-13-2010, 09:17 PM   #3
FED 387
Liked 333 Times in 180 Posts
-try adjusting shoes til they start to drag ---then when you get into the water box pump the brake pedal a few times til it starts to get hard---you'll feel it in your foot--- then with the pedal still on the brake pedal set the line loc ---then start your burn out see if this helps--worked on my 67 camaro with drum brakes--Comp
Old 07-14-2010, 06:09 AM   #4
Billy Nees
Liked 7,782 Times in 1,743 Posts
Ken, have you put new lining on it lately? Did you have the new lining re-arched to the drums?
Billy Nees 1188 STK, SS
Old 07-14-2010, 06:10 PM   #5
njk53
Billy Nees might be onto something. We had the same problem that drove us crazy. We put on new brake pads and new rotors. Turned out that we didn't have the above broken in properly.
Nelson Kowal
Stock 345
