Old 07-20-2010, 01:33 AM   #11
Jeff Lee
Jeff Lee's Avatar
Default Re: spark plugs
And the real dyno reports and ET improvements are.....?
Jeff Lee 7494 D/S '70 AMX
Old 07-20-2010, 07:54 AM   #12
Chris "drooze" Wertman
Chris "drooze" Wertman's Avatar
In out case Jeff, well.....they are the only plugs that they make for the heads that come in 1,2, 3, 4 and 6 colder than stock And in both retracted and projected tip.
The retracted I believe Art may have seen a difference in, we dont have an established enough baseline.
But our only other REAL choices are NGK Iridium (expensive and delicate) or 1 other I can remeber in the heat range we need to keep from predeting to hell and back.
Chris "Drooze" Wertman 3132 (F/SA 2009 Challenger Drag Pak #24 with a best of 10.59)
Chris "drooze" Wertman is offline   Reply With Quote
Old 07-20-2010, 08:11 AM   #13
Rich Biebel
Rich Biebel's Avatar
Liked 544 Times in 213 Posts
"predeting to hell and back"
I know about pre-ignition
I know about detonation
I know about running on/dieseling or "Hangfire" as one of my customers used to call it in my garage days....
But..... predeting to hell and back is new to me......
S/G and S/C cars never have that problem anyway, whatever it is.....
Rich Biebel
S/C 1479
Stock 147R
Old 07-20-2010, 09:44 AM   #14
FED 387
Liked 333 Times in 180 Posts
Rich/and others-- predeting is a quite common occurence in the "rice burners" and others high performance engines-- It can cause major problems if not corrected in time- you absolutely must pevent predeting or you can have catastrophic engine damage---Comp 387
Old 07-20-2010, 09:49 AM   #15
Im assuming you know what I meant, take a stock DP engine and try to run it with the plugs that are in it (oe stock) at 12.5 : 1 and youll soon find out, NGK only makes a 1 step colder than 6.1 stock.
Brisk because of demand on the SRT4's running high boost came out with a whole line, and because of the Hemi cast in plug tubes you have little choice if you want a plug that actually fits.
Pre-Ignition, Pre-Detonation, Detonation, Knock, Ping.....whatever....all semantics....
Old 07-20-2010, 11:11 AM   #16
SSDiv6
Liked 1,600 Times in 583 Posts
Talking Re: spark plugs
Is it related to "Predetinating"...the Redneck word equivalency for "Predetonation"?
...or related to the word predator or predate?
Old 07-20-2010, 01:20 PM   #17
Jeff Lee
Jeff Lee's Avatar
I thought it was something about "predator" as in "a hunter". "He was hunting to hell and back"
Old 07-20-2010, 01:48 PM   #18
Rich Biebel
OHH so it's kind of like reverse Hangfire........Motor goes fraff-fraff-Run-No More......!!!!
I am still trying to understand points myself......it just escapes me how something pointy can make a spark.....
Rich Biebel
S/C 1479
Stock 147R
Old 07-20-2010, 02:19 PM   #19
Jim Wahl
Jim Wahl's Avatar
Liked 683 Times in 129 Posts
Or the Cajun term "pre dat" meaning "before that". Jim
Old 07-20-2010, 02:57 PM   #20
Default Re: Predeting spark plugs
I'm trying to learn a new word today, too.
I found this usage in the cross dresser's forum, but I don't think it's the same meaning:
" I'm totally for fitting in.
Even standing out can be done in a couple of ways. There's a tasteful way, and there's a questionably tasteful way.
Most school girls and, to my belief, a good part of the crossdressers that want to stand out, pick the distasteful and shrill way. Then again, I'm not predeting that I've seen them all. Just my 2 cents...
_________________
-- Alizee "
