Old 08-08-2010, 10:14 AM   #1
Cisco Kid
Cisco Kid's Avatar
Send a message via AIM to Cisco Kid
Default Re: carb spacers
michael,what i have done so far was make a electronics panel,that has my delay box and trans brake timer on it and installed weather pack connectors on all the boxes so i can easily remove them,the panel is also just mounted with dzus fastners,at or points meet at trails i talked with tech,and he said that i must remove all the electronics and even the stop off the intake...is it possible you can scan the letter you recieved and email it to me?? cause what i can do is leave it alone and just take the letter and my new spacer which cost 169 bucks and if i dont have to use it i will send it back...the rules are so vague that they tend to not explain the details,and i plan on testing next week to figure out my shift point to get down to 10.0...and i hate to change everything then have to go from square 1 on time trails...but thanks for you help...my email is seszko3@aol.com
thanks again
Cisco Kid is offline   Reply With Quote
