#11 |
I wouldn't even consider it. It has more to do with weight, but I tow a 28' enclosed trailer with a GMC2500HD Diesel and it's the smallest truck I would use. Should've gotten the 3500 dually...
Chris Williams 6304 SC, TD, ET |
#12 |
Do you its possible for me to find a pretty good decent 250 or 2500 for $15 to 17$k?
most of the one's i see i can afford have 100,000 miles on them is that alright? |
#13 |
Is it bad to get a gas motor in a 250 or 2500 ?
#14 |
Liked 334 Times in 181 Posts
100 thou on a 7.3 ford or a Cummings is nothing these engines will go 300thou easily if they have been/are taken care of STAY AWAY from the Ford 6.0 or 6.4 NOTHING BUT EXPENSIVE MAJOR PROBLEMS!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! a V10 gas motor in a Ford is a good engine 5.4 is underpowered not enuf HP /torque there to move that weight-late model Dodge with a Hemi not too sure about most guys run the Cummins " The Duramax is a good engine but hard to find and pretty pricey if you find a truck with one in it-Its all about do you want to control the trailer or do ya want the trailer to control you"---You can use a 1/2 ton but it is not advisable brakes and suspension just cannot handle the load safely--Comp
#15 |
What about the 250's or 2500's with a V8 Gas motor? finding the used v10's are not easy lol. what about the v6 cummins diesel's?
#16 |
reading on here a bunch of guys pulling 24 foot enclosed trailers with GMC or Chevy 1500's.
http://www.yellowbullet.com/forum/sh...closed+trailer hmm ? |
#17 |
what about the z71's?
#18 |
Liked 3,230 Times in 982 Posts
Cummings + Dually and you'll wonder why you considered anything else.
#19 |
dont believe i can afford that
#20 |
anyone hear good news about 2500 dodge ram w/ a hemi?
