Liked 6 Times in 5 Posts
How often should you freshen a bracket motor? I have about 125 passes on my motor. thanks 1 season
Liked 3,232 Times in 983 Posts
What kind of output and E.T are you talking about?
600 hp and runs 10.15 at 132.00
Liked 484 Times in 160 Posts
Aluminum rods ? makes a difference.
If it's running well and has good components (like premium rods) then 300 runs should be ok. Lots of variables like radical cams and RPM range but 200 runs would be the minimum you could expect to get out of it.
My 383 13-1 flat tappet,Iron eagle plat heads,has 500 runs on it and I'm just now going to freshen it.Motor is in my 68 camaro that weighs 3125 and runs 10.32@130 with a glide.
http://stevecoxracing.com |
if the engine has good stuff in it 300 is a safe # ck the liftes at this point. throw the rods away after 600 pass
If it has steel rods then 300-400 should be fine.
Jason Haley 86 Olds Cutlass bracket car 12.49@106, 7.79@87 best so far! |
