Old 05-29-2007, 05:37 PM   #3
SST159
Liked 20 Times in 16 Posts
Default
Dave,
Thanks for the response.
I did check the pickup clearance and it is within the correct range however I learned today that the Melling pickup I am using may not be far enough back in the pan as needed. I am using restrictors and I am using a Melling race pump that is the anitcavitating +10% volume.
My next step is to try a Moroso pump and pickup package that they match to the exact pan I use. The Moroso pickup is a bit different from the Melling.
Drew
S/ST 159
Drew Wonderly
SST 159
SST159 is offline   Reply With Quote
