Liked 3 Times in 2 Posts
Stay away from "Black Streak Removers". They do a heckuva job of taking away black streaks, but they leave "White Streaks" if you're not careful.
Scotchbrite works well on the aluminum floor...all you need is a case of that, a sanding block, and a free weekend. After that initial scrub, there are aluminum waxes that make it easier to restore the shine - make sure you wipe up any water or fluid that might hit the floor and it'll last for a while.
Joe Hertline 1318 SS/FA |
Liked 336 Times in 183 Posts
Ditto on Simple Green do it in the shade and start at the top and work your way down---Get it at Wal mart for about $8 a gallon--its cheap and effective & it works well
Liked 56 Times in 27 Posts
Wayne..... You have a PM.
Dave Ribeiro 1033 STK Last edited by Dave Ribeiro; 05-17-2011 at 10:47 PM. |
Use RV455 to remove tough black streaks and grime. I was sceptical until i used it and It removed black streaks from a trailer that was sitting and not washed for 6 years by just spraying on and wiping off. It strips off the black streaks as well as any wax, so you must wax it right after cleaning.
Liked 6 Times in 4 Posts
I use this product, and it works very well on "streaks". Be aware.... It is pretty aggressive. Don't use it in the sun (surface should be relatively cool), and rinse with clear water before it dries......
Is it a soloution that could possibly be deluted and mixed in with water in a bucket ?
[QUOTE=Joe Hertline;243895]Stay away from "Black Streak Removers". They do a heckuva job of taking away black streaks, but they leave "White Streaks" if you're not careful.
X2 on that for black streak removers. They will take off the black streaks, but wait to you see what it does to your shiny aluminum trim, it spots and tarnishes them, and I followed the directions. Learned my lesson the hard way. |
Liked 3 Times in 1 Post
Along the same line what wax are you guy's using after it is clean? Thanks, Brian
I have freind that owns a detail shop that races with us in superstock up in the northwest that has a special mix for trailers and RV u can call troy at NW Quality detail (253)351-0809 he sell supplys to
