Old 03-16-2011, 11:42 PM   #21
Mike Carr
Mike Carr's Avatar
Liked 83 Times in 37 Posts
Default Re: Drag Racing analyzer
Sean is correct. There is some type of counter mounted on the front tire/axle, to measure time/distance. I read about all the Matty Box stuff years ago, I don't remember all of it, how it worked, etc.
To my knowledge, other than Matty, who was protested, refused to tear down, and was tossed, at the 1999 Moroso 5 Day, none of the others were found to be illegal at any time. Not sure if they were ever protested (or found illegal). I apologize if I am incorrect.
*edit* I did find this. http://racingarticles.com/article_racing-11.html
Old 03-17-2011, 12:14 AM   #22
Sean Kennedy
Sean Kennedy's Avatar
Send a message via AIM to Sean Kennedy
Originally Posted by Phillip marvetz View Post
How do you attach it to your front wheel Sean?
It's magnetic, get creative.
2002 Division 6 High School Champion
2007 Division 6 Pro Champion
2007 Division 6 National Open Series Stock/Super Stock Champion
Sean Kennedy is offline   Reply With Quote
Old 03-17-2011, 03:12 AM   #23
Ken Haase
Talking Re: Drag Racing analyzer
Would it raise any eyebrows if you just used one of those bicycle wheel contraptions on the rear of the car, like Motor Trend magazine uses?
Ken Haase is offline   Reply With Quote
Old 03-17-2011, 09:39 AM   #24
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 319 Times in 108 Posts
If i remeber correctly Matty won 1989 IHRA bracket finals @Bristol,I think he also won race of champions there also driving red 62-64? chevrolet.
I was always told the Matty box would adjust car to dial that may been myth,I was told usaully had NOS to pick up or pull timing to slow? Does anyone know those facts?
Mike Taylor 3601
Old 04-24-2011, 12:26 AM   #25
cicero819
cicero819's Avatar
Liked 70 Times in 31 Posts
Matty is now involve with NHRA un-leashed.
Old 04-24-2011, 12:36 PM   #26
Ed Fernandez
Ed Fernandez's Avatar
Liked 100 Times in 45 Posts
Maybe like the govt.Use a cheater to catch a cheater.
Former NHRA #1945
Former IHRA #1945
T/SA
Old 04-24-2011, 12:47 PM   #27
Ed Wright
Ed Wright's Avatar
How could it actually adjust the car? Or did it signal the driver about where it was in relation to the dial? All that came about while I was sprint car racing and then quit.
Ed Wright 4156 SS/JA
Old 04-24-2011, 04:10 PM   #28
7423
Angry Re: Drag Racing analyzer
I'm sure it did all that plus!! Worked for Connley and look at him now, he's a NHRA Pro Stock racer!! A great competitor for todays youth to look up to.
7423 is offline   Reply With Quote
Old 04-25-2011, 08:05 PM   #29
Mike Carr
Mike Carr's Avatar
From stories I read, the Matty Box was like a cruise control. If the car was ahead of it's on-track point (running quick), the throttle stop would kick on to slow the car down to run it's number. If it was behind it's on track point (running slow), the N20 would engage, pick the car up, and run dead-on it's dial.
Old 04-25-2011, 08:29 PM   #30
K Stubbs
Liked 20 Times in 3 Posts
With the Matty box, after the first initial run to record data, you do not need to make another time trial. As long as the run is good (no tire spin, gear change malfunctions etc) The box records that data and uses it to determine the following runs ET prediction by counting the amout of times the engine fires compared to the distance it has traveled, thus the reason for the counter. It will tell you, by led, if you are going too slow or too fast. You can use nitrous, throttle stop, etc to control this. You can also use it on a footbrake car without a transbrake with a motion sensor that is available. In my opinion, with todays consistent bracket cars, like dragsters, the box would be less helpful. You still have to hit the tree and is appears many can do this and run the number.
K Stubbs is offline   Reply With Quote
