Liked 93 Times in 52 Posts
Liked 1,887 Times in 579 Posts
is that a 1050 dominator style or a 4150? i have both, i use a little more jet in the dom. 92 sq. 86sq in the 4150. every engine is slightly diff. but you seem very close....
When I ran a Dominator, seemed like the 92 range was good for most smaller BBC's like yours...Maybe invest in an EGT so you can see a little closer, but you should be very close...
Dave Steltz 135G SG/SP/SST BIAECH Racing Team |
Liked 362 Times in 105 Posts
Another important part of jetting is what the adjusted altitude you are running at is and what squirter you use.
You can run a leaner jet and use a bigger squirter to keep it from stumbling at the starting line but you may still be lean on the big end. Consider more than jet size alone. My 2 Cents Rick Cates |
you could try a smaller hi speed air bleed
Wayne Sipos HR 3959 |
I had almost the exact same combo except mine was 461 cube....I ran 94 square and have even had 96 in the back in better air....
Good luck!
Ron Finney 396V S/C |
Thanks Guys
I Put in a fresh set of plugs tonight, and I guess I'll fatten it up a little tomorrow and see what happens. ![]() Cal HR 177X |
