Old 05-25-2011, 09:42 PM   #1
Capri
Liked 27 Times in 14 Posts
Default Re: Trailer tire opinions
As long as you obtain the "D" load range tires you will not have any issues. B and C can gice you headaches if you are carrying alot of weight.
For sure, stay away from Carlisle. If you have a Pomps Tire in your area you will not spend a ton of cash. If not, I can try getting them for ya. I seem to recall they are around $100 each.
Capri is offline   Reply With Quote
Old 05-31-2011, 06:00 PM   #2
mike withers
Liked 3 Times in 1 Post
Exclamation Re: Trailer tire opinions
sorry for chiming in late on the issue but "E " rating 10 ply tires are now available for 15" rims. They allow more air pressure 80lbs. and fewer problems with heavy trailers and interstate travel. I have used them on my 24 ft box for last couple years with good results.
Mike Withers 1195 SS
mike withers is offline   Reply With Quote
Old 05-31-2011, 06:58 PM   #3
jim powers
jim powers's Avatar
Liked 13 Times in 10 Posts
maxxis load range e
jim powers is offline   Reply With Quote
Old 05-31-2011, 09:32 PM   #4
FED 387
Liked 336 Times in 183 Posts
Question Re: Trailer tire opinions
OK so we do not buy Gyear or Carlisle---maxxis ok??? Pomps what brand ??? Loadstar mixed answers here---does any one make a load range D or E that comes in a 15 inch tire or can I use a HD LT truck tire?? or does anybody know where I can get 5 lug 16 inch wheels??? If I hafta go to 16 inch wheels everything I've seen is 6 lug which means I hafta go buy new brake drums/hubs too in addition to the wheels and tires now ya start talking some serious money with hubs/wheels/tires involved like easily maybe $1300-1500 dollars for the whole thing---my current tire is a 225/75/15 load C and I haul a 1000 pound dragster with the normal stuff but NO golf cart--Comp 387
Old 06-01-2011, 09:31 AM   #5
BlueOval Ralph
Banned
One thought is if you have to buy drums backing plates you might want to check out the next axle upgrade and get the axle asm that has the 16 x 6 bolt circle proably gets you bigger brakes and larher wheel bearings also. Did you know that the Dexter 3500 lb axles use a Pinto/Maverick outer wheel bearing?
Just a Thought
BlueOval Ralph is offline   Reply With Quote
Old 06-01-2011, 06:27 PM   #6
FED 387
mike withers sent u a PM
Old 06-01-2011, 10:08 PM   #7
Run to Rund
Liked 56 Times in 29 Posts
My independent tire dealer (OK Tire) told me Carlisle has made big changes and are no longer the "worst". They are made in USA. OTOH, Goodyear Marathons are now made in China as are almost every other trailer tire. I've had problems with the Chinese rubber "dry rotting" prematurely.
Old 07-08-2011, 09:31 AM   #8
Mike Graham
Liked 341 Times in 67 Posts
Wheels of mid 80's Lincoln MK 7 are 16 inch forged Al. They are 5 lug pattern. I put them on my trailer with load range G tires. Tire problems went away. These wheels are cheap at wrecking yards.
Mike Graham is offline   Reply With Quote
