can any one help me get a 2100lb. car to run 10.90
the car is a 91 camaro roadster aero as all hell |
I have the heads and intake that could make that happen real easy. I know where there is some assembled short blocks that could be had real cheap that ran in the 8's at more weight than that.
Liked 1,891 Times in 423 Posts
Tim Cole (Comp Cams) has a V6 powered Corvette Super Stock car that runs mid 8 second ET's.
Adger Smith at one time had a very fast V6 Camaro. So, yeah, it can be done.
Alan Roehrich 212A G/S |
Liked 20 Times in 9 Posts
It depends on if you are talking racing v-6 engine or a factory installed v-6.
A split pin 4.3 crankshaft won't go 10.90 very many times. A common pin, odd fire crank, would be what you would use. So the answer is a production 4.3 isn't a good choice.
Liked 229 Times in 99 Posts
Andy Manna had his record setting V6's for sale a short time ago.
Floyd Staggs 787 SST |
Liked 880 Times in 311 Posts
It can be done.
you tube of my SS/DS Camaro in testing a couple of years ago. All steel 1986 Camaro, Single 750 holley, 3200 lb, no Nos, 277 cu in, Pro flite 3 speed 2.12 low gear tranny, Leave chip 6800, shift 9400 - 8,000 stall. I had the same engine in a 2200 lb roadster that ran some 8.80's - 150's mph with a PG tranny With the right parts 10.90 is a cake walk. You will struggle and destroy stock 4.3 engine parts. . I talked to Tim Cole and he has a nice Buick headed V-6 that would haul your 2,000 lbs real well. It is priced very reasonable. Get in touch with him @ Comp Cams or call me and I'll give you his cell # Adger 903 824 4924 cell 903 794 7223 shop
Adger Smith (Former SS) Last edited by Adger Smith; 07-22-2011 at 12:01 AM. Reason: commemt |
Liked 719 Times in 220 Posts
I have three blocks and several stock heads and a bunch of parts for those. All of them have the steel roller cam, and they are take outs from S-10 trucks and an Astro van. If some racer wants them, he can pick them up for free from my house. I had an S-10 Blazer that was going to need an engine. I never got around to rebuilding one of them, and we got rid of the Blazer three years ago.Everything goes in one lot.
