Old 10-05-2011, 11:45 AM   #1
Jeff Lee
Jeff Lee's Avatar
Default Re: Roll Cages vs. Roll Bars in higher class cars
No you do not have to remove the roof. The top portions of the bar are tack welded in the car and the lower legs are dropped through the floor sections so you can get a 360 degree weld on all of the top portions. Afterwards the bar is raised and secured to the floors.
Jeff Lee 7494 D/S '70 AMX
Old 10-05-2011, 11:51 AM   #2
Larry Curtis
Larry Curtis's Avatar
Liked 9 Times in 2 Posts
The only downside to runnig a cage is that it has to be certified every 3 years. A roll cage that is not NHRA certified is only good to 11.50 et, a roll bar with a un-modified floor pan is good to 10.00 et. I would still put a roll cage in. $0.02
Larry
Larry Curtis is offline   Reply With Quote
Old 10-06-2011, 02:03 AM   #3
GTX JOHN
Liked 2,486 Times in 697 Posts
My understanding is that the Cage only has to be certified if the car
is fast enough to REQUIRE it to have a cage.
My car has had Cage and been race continually for 18 years and show
No Flex of Body unlike a lot of my other cars. I believe that it further makes
the car stiffer and easier to tune chassis. We did remove Windshield to
Fab it and get everything to fit as close as possible.
Old 10-06-2011, 02:56 AM   #4
Phillip marvetz
Phillip marvetz's Avatar
Larry
Are you sure about that? Makes no sense................
2009 V/SA Record Holder
Old 10-06-2011, 06:37 AM   #5
rallye bob
rallye bob's Avatar
Liked 6 Times in 4 Posts
Larry
I also think this is incorrect..... No cert. required on a cage until a 9.99 et is attained...
I run a cage, no cert. @ 10.31 et....
Old 10-06-2011, 09:11 AM   #6
SCOTT SST2871
Originally Posted by rallye bob View Post
i also think this is incorrect..... No cert. Required on a cage until a 9.99 et is attained...
ditto
SCOTT SST2871 is offline   Reply With Quote
Old 10-06-2011, 09:26 AM   #7
Larry Curtis
There is a track in WI that states that this is a rule, but I just looked it up and the rule specifically states that you only need a cert if you are running 7.50-9.99. Sorry for the misleading information.
Old 10-06-2011, 11:48 AM   #8
Ian Hill
Ian Hill's Avatar
Liked 6 Times in 3 Posts
also, contradictory to what was posted below and another post a couple months ago on this board, that overly bashed a chassis builder for not fully welding the cage on the halo attachment points. the cage does not have to be fully welded. as long as the cage is properly fit and welded properly 3/4's around the tube and corner gussets are added then it will pass tech with flying colors! gussets can be in the form of small corner plates or small diameter round tube. this is how chassis builders are able to tuck the cages up to the headliner real tight on cars without cutting holes in the floor! those silly little gusset plate or small diameter roll bar tubing welded in the corners aren't just there for looks.
don't let the flashy paint fool you!
Ian
Ian Hill is offline   Reply With Quote
Old 10-06-2011, 12:42 PM   #9
69Cobra
Liked 2 Times in 2 Posts
Interesting...
Kris Rachford
69 Cobra 428CJ 4 Speed
C/S 3032
Old 10-07-2011, 01:21 PM   #10
J&P
Question Re: Roll Cages vs. Roll Bars in higher class cars
Ian
Where are you getting this from?Where in any rule book does it state this?There are ways of welding these joints 100%... anything less is hack
Pete
J&P is offline   Reply With Quote
