Old 10-11-2011, 10:08 PM   #1
reknapp52
reknapp52's Avatar
Liked 7 Times in 5 Posts
Default Procharger Question
Is anyone using a Procharger on a throttle-stop car? If not, do you think it would work?? What issues would have to be overcome?
reknapp52 is offline   Reply With Quote
Old 10-13-2011, 05:12 PM   #2
MOTORSPORTS Innovations
MOTORSPORTS Innovations's Avatar
Liked 15 Times in 2 Posts
Default Re: Procharger Question
They all keep bugging me to try it, but I have resisted so far. I would think it would work fine with EFI and probably with mech FI. Blow thru carb I wouldn't do.
Mine is EFI http://www.motorsportsinnovations.co...rocharger1.htm
Greg Kelley
www.motorsportsinnovations.com
MOTORSPORTS Innovations is offline   Reply With Quote
Old 10-14-2011, 10:31 AM   #3
reknapp52
reknapp52's Avatar
Why not the blow-thru carb? I'm running a carburetor now, of course. Also, what compression ratio would be to high to use a Procharger with? I'm currently over 13 to 1, and using Trak Tech 112 racing fuel.
Old 10-16-2011, 09:18 PM   #4
Not saying I know a carb to be a issue, just that I use and know EFI and how well it can adapt to things.
My compression is 11.1 and I 'm using alky. Most gas guys are 8.5 or low 9 to 1 compression
Old 10-23-2011, 05:14 PM   #5
Jason Robertson
Jason Robertson's Avatar
you can run your 13:1 but your gonna have to convert to methanol. a blow thru methanol carb on a stop.......hmmmmm
Jason Robertson is offline   Reply With Quote
