Yes, any material. Just cannot be smaller than 10" diameter.
By the way....this will be a leaf spring car with Calvert stuff underneath the rear and a 28x9 tire. Just don't think it needs a 10.5" slick at this power level. |
I started to write it all out but decided not to tell any of your competitors that may be lurking...check your PM
Jeff Lee 7494 D/S '70 AMX |
I see you don't allow PM's. Email
JeffLeeAzRealty@gmail.com
Liked 54 Times in 27 Posts
You just need a shop savvy in diaphragms, like South Bend Clutch, to work up a pressure plate with fairly low pressure to work with the same #5135 sintered iron disk that the adjustable clutches use. In my car 1100 with a Borg and Beck wasn't enough, 1365 lb. with double rollers was plenty. I haven't tried anything in between yet, as the latter setup is working well.
#5 | |
Thanks! |
