Old 10-17-2011, 09:54 PM   #1
Seate Boys
Default turbo 400 question
Keep busting the case on my camaro,in the bell housing area.Want to go to the "JW Ultrabell",one is an "LS" part number and one is not.I assume it means long shaft,what's the diff.All the casings I've had look the same
Seate Boys is offline   Reply With Quote
Old 10-17-2011, 10:13 PM   #2
Tom Goldman
Tom Goldman's Avatar
Liked 883 Times in 237 Posts
Default Re: turbo 400 question
The LS suffix means it will fit all GM engines including LS series .
you want the 92451 for the TH400
Old 10-18-2011, 09:43 AM   #3
Seate Boys
Thanks Tom,the guy at Summit said he showed 2 #'s,one understood by him 2 b long shaft
Old 10-18-2011, 10:03 AM   #4
A TH400 case is very tough, if you're breaking them, the problem is not likely to be the case. The most common problems are drive shaft, motor mount, and chassis problems. The case on a TH400 will take well over 1000HP with ease, provided you do not have another problem.
Old 10-18-2011, 12:28 PM   #5
Tom Goldman
Alan, I agree the 400 is one tough case ,but lately the supply of used cores from the salvage yards seems to be getting pretty beat up.
I've had several salvage yard cores recently with cracks showing up in the bell area after they were cleaned.
The other issue I've seen is from cars that are big wheelstanders with no mid plate. i.e. Stock and some brackets cars. Not that many racers run them in Stock anymore.
They seem to have more issues with cracks than others.
Old 10-18-2011, 01:31 PM   #6
Tom, my only point was if that if a racer is cracking cases that did not start off cracked, changing the bellhousing is not necessarily going to solve the problem, and it may only make the case break somewhere else.
When I was the manager of the racing side of a very successful transmission shop, I found that it was extremely rare for a case to break of its own accord. The vast majority of problems, as you said, were due to either chassis flex, or motor mount problems, although we did find a few driveshaft problems.
A big concern is that if the bellhousing is breaking, and you replace it with a stronger bellhousing, and don't resolve the cause of the breakage, the next place it breaks is behind the pump, and that creates a fluid loss hazard that can cause a crash and/or a fire.
Old 10-18-2011, 07:28 PM   #7
Tom keedle
Tom keedle's Avatar
Liked 8 Times in 7 Posts
solid trans mount maybe?
Old 10-19-2011, 12:29 AM   #8
Jimmy70RSSS
Liked 2 Times in 1 Post
Had a friend with a similar problem with a T400. After changing the bellhousing it would strip the pump bolts and dump fluid! Chassis flex was the problem. Converted to a 10 point and tied the frame where the backhalf met the stock front and it hasn't hurt anything in 3 years.
Jimmy70RSSS is offline   Reply With Quote
