ok thanks. would be running s/gas
Liked 100 Times in 51 Posts
If you use a HANS device, you will still need the neck collar, OR a head sock, OR a skirted helmet. It is in the 2012 rules amendments.
Liked 335 Times in 182 Posts
WRONG WRONG!!!!!--- go back and read the rules amendments for 2012 EITHER collar or HANS -- however some classes /some types of vehicles(open/closed) some ET's Some MPH a HANS is required in lieu of a donut-----read it closely!!!!!
If I remember correctly, the mfg'rs of the Hans and Safety Solutions units ( I have the pro-rage) tell you to NOT wear a neck collar with a restraint, it will interfere with proper fit and operation...I know with the rage, I dont see how I could wear the collar and not have it mess with the teathers and release strings...
Also if you wear a restraint, you must have a head sock or helmet skirt...
Dave Steltz 135G SG/SP/SST BIAECH Racing Team |
the only places I see a skirt or sock required here is for FRONT ENGINE or Supercharged or turbocharged vehicles or in some instances Nitrous cars---be damned if I can find where in the 2012 rule book OR 2012 amendments that with a HANS you MUST use a sock or skirt---please enlighten me where does it say that--I looked thru the rule book for over an hour and I do not see that anywhere---not talking about any Alcohol or Nitro classes either--thanx Comp
I just received an email from NHRA tech, Pat Cvengros, You do not need the neck collar BUT you will need the head sock or skirted helmet.
Here is the email content. If I decide to use a HANS type device, (not a class requirement) while racing in SG and/or SC. 1. Do I still have to use a neck collar? 2. If no neck collar, do I have to use a head sock or shirted helmet? Thanks, Dan Foley No you would not be required to use a neck collar if you used a head and neck restraint system. You would however need a head sock or skirted helmet. Pat Cvengros |
You're right finally found it it is under the PROTECTIVE CLOTHING section not in the helmet or neck collar restraint area---
I just hate it when people are so adamant about telling how wrong I am..........LOL
hey smart ***----it is not necessary to wear both the HANS & the donut
ONE OR THE OTHER is OK---as far as the head sock we ran using a HANS all of 2010 and most of 2011 NEVER HAD A SOCK OR A SKIRT nobody ever questioned it---maybe we just got lucky and got away with something BUT if we had known that it was mandatory no problem we would have gotten one---not trying to skate on the rules just never knew we needed it---as far as being adamennt YOU CAN USE A HANS WITHOUT A COLLAR if you want to use one it's up to the racer but it is not necessary---as I said one or the other is OK--- end of discussion |
You need two things: whiplash protection and fire protection. A collar provides both. A head-and-neck device only provides the former, so you need a sock or skirted helmet for the fire protection. This is not new, this has been in place since head-and-neck devices were approved.
FWIW, I wear a Hybrid Pro with a head sock.
Chris Williams 6304 SC, TD, ET |
