I knew a guy who ran a turbo street-driven Camaro in SST back in the late 80's. I know a couple of people who have run turbo diesel pickups in SST. I plan to run SG or SC occasionally with my new truck I am building (turbo diesel pickup).
I am pretty sure the rule is just laying down restrictions for the superchargers, and effectively is NOT restricting what type of turbos you can run. However there is a section in ET and general regs that increases the firesuit requirement for turbo or nitrous cars without an OEM or 0.024" steel firewall.
Michael Pliska 643 S/G |
Liked 6 Times in 4 Posts
Thanks, Michael!!! Good luck with your project!!
Bill |
bill, i ran a twin turbo small block 69 camaro in super street from 1995 till 2001 in div 6, never had a problem in tech. bob munoz
Hey Bob, how's it going? I was referring to Ramon's Camaro above, but I knew you had run one as well (but I never saw it since I lived on the East Coast during those years). Don't know if you remember me, I have the "Student Driver" Super-Gas Vega. What ever happened to Ramon? Remember when your brother and I used to bet a $1 bill on round wins when we ran head-to-head? I still had that $1 bill until a few years ago. How is he doing these days? Sorry to derail a thread, but haven't heard from Bob in years!
#5 | |
I do appreciate the input!!!
Bill |
Liked 4 Times in 1 Post
You may want to investigate the launch control that the Pro Mods use cut good lights on a .400 pro tree. As I understand it, it's much like a 2-step, except that it retards the timing so much that it causes an explosion of un-burnt fuel in the header tube. The force from the explosion spools up the turbo in less than half a second.
Tony Curcio 1860 STK |
Normally, the anti-lag you're referring to requires timing at about 40 degrees AFTER tdc. You could try stalling the car in second gear with the transbrake button held down. The brakes should be able to hold it at full boost and the transbrake won't operate in second gear. When you're staged, put it into low to activate the transbrake. The transbrake will hold the car since the brakes won't in low. Just a thought.
There's also a device that delivers an adjustable pulsed signal to the trans brake solenoid. When activated, it allows the car to creep forward slowly with the trans brake applied and the car at full boost. Might be hard on internal trans components though. Good luck! |
This is what Bruno Massel uses to spool up rapidly with his world-champ turbo car in Comp eliminator. His father's customers are mainly in Top Dragster and other fast bracket cars with a torque converter.
http://www.brunosautomotive.com/brc.htm About one paragraph up from the bottom is the phrase "Now Available - Dual Stage Pressure Assembly for turbocharged power plants that allows for ease of "Spool up"!"
