Old 02-28-2012, 08:38 AM   #1
FrankM
FrankM's Avatar
Liked 3 Times in 2 Posts
Default Re: 3rd gen camaro throttle linkage?
I may not have worded the question properly. I am installing a throttle stop (Biondo PCTS-SH) and the factory cable I believe is not a good choice due to too much stretch for consistency. Do you guys have recommendations, solid linkage or morse? I will only be cutting .3 to .5 ET. If you have done this can you send pics.
Thanks,
Frank
FrankM is offline   Reply With Quote
Old 02-28-2012, 12:35 PM   #2
Ken MacNicol
Ken MacNicol's Avatar
Liked 26 Times in 12 Posts
I use a inline with a factory cable and CSR bracket with no problems.
Ken MacNicol is offline   Reply With Quote
Old 02-28-2012, 01:38 PM   #3
FrankM
FrankM's Avatar
Ken, are you running a dominator or a 4150? Which CSR bracket do you have? I'm running a 4150 and have a CSR bracket for the snap in cable that I've been using without the t-stop but didn't think that will work. Thanks for the help, need all I can get.
Old 02-28-2012, 04:15 PM   #4
Keith 944
Keith 944's Avatar
frank, if you are that close to the index, i would just add weight. this can be VERY consistant. and could save you a lot of time and $.
KEITH MAYERS
2-1/2 X somebody
Still many X nobody
Old 02-28-2012, 05:31 PM   #5
Ken MacNicol
I ran a 4150 until last year, but now have a 4500. They do not have a extended bracket for a snap in cable, so I modified mine a little. I still have it if you are interested.
