Old 03-13-2012, 09:31 AM   #71
Paul Merolla
Paul Merolla's Avatar
Liked 293 Times in 65 Posts
Default Re: Project update
Got a call from Dave on Friday to say, "We ran out of stuff to do to your car." So yesterday, I had a big day - Picked it up from his shop and delivered it to another Dave for the vinyl roof install.
Paul Merolla is offline   Reply With Quote
Old 03-13-2012, 09:40 AM   #72
Curt Rees
Liked 251 Times in 51 Posts
Talking Re: Project update
Gona' be a nice car, Paul!
#5457
Curt Rees
Curt Rees 5457 SS
Curt Rees is offline   Reply With Quote
Old 03-13-2012, 10:19 AM   #73
Ed Carpenter
Ed Carpenter's Avatar
Liked 520 Times in 132 Posts
Looks great!!!
Ed Carpenter
2005 Chevy Cobalt A/SM
Race Engine Development
Old 03-14-2012, 02:19 AM   #74
JP
JP's Avatar
Nice!
JP is offline   Reply With Quote
Old 03-14-2012, 06:38 AM   #75
dartman
dartman's Avatar
Liked 68 Times in 41 Posts
Car look's great ,but where does it say you can use that rear end cover.as it not stock and also not in NHRA Accepted Products list. clearly state that it has a performance advantage.
High tensile aluminum alloy
Eliminates case distortion
Controls unwanted gear deflection
Provides additional clearance for low gear ratios
Allows aftermarket main caps and main cap stud kit installation
Increases fluid capacity
Reduces operating temperatures
Correct mounting fasteners included
Step-by-step instructions for a simple bolt-on installation
Originally Posted by Paul Merolla View Post
Don't see much of this type of post on classracer, but I enjoy seeing them on other boards I frequent, so here goes. Project is a 66 Nova...327/275 stick combo...bought it in '02 out of a barn:
Tore it apart, hung new quarter skins...then made a little room for tires:
Blasted the underside...made subframe connectors...installed rollbar:
That was all by the end of '03. Slacked on the car, got divorced, moved, etc. etc.
Fast forward to this fall...epoxy primed the underside, POR-15 on the floor and trunk, assembled rearend (thanks, Larry!) and as of last night, it's off the rotisserie!!
1231 FS/D Drag Pak
1231 E/SA 71 Demon
Kelly MacKay
dartman is offline   Reply With Quote
Old 03-14-2012, 03:12 PM   #76
Paul Merolla
I hope you're joking....if not, you haven't seen underneath very many stockers these days! As for the rulebook, it doesn't say anything about differential covers the last I looked.
Old 03-15-2012, 05:56 AM   #77
james schaechter
Liked 1,439 Times in 301 Posts
The brace and cover really is a good way to keep a stick car from bending axle tubes.
They aren`t anything controversial in the stocker ranks for sure. We bent the left tube on our Nova when we first ran it. We put the brace kit on after straightening it and it is still good 10 years later!
Paul the car looks great!
James Schaechter 3163 STK
Old 03-15-2012, 09:41 AM   #78
Eddies66
Eddies66's Avatar
Liked 881 Times in 452 Posts
Great job, the joy of 2nd gen Novas! What size tire did you end up on the back?
Eddies66 is offline   Reply With Quote
Old 03-15-2012, 10:04 AM   #79
ron mattson
Liked 68 Times in 31 Posts
looks great keep working your almost there, the hard stuff is done and your so
close im sure you cant wait to run it!!!
Ron Mattson 5015 STK
ron mattson is offline   Reply With Quote
Old 03-15-2012, 10:44 AM   #80
MEXJOE
MEXJOE's Avatar
Liked 165 Times in 51 Posts
I love the 66-67 chevy II! THAT ONE LOOKS REAL NICE!!
Good luck with your new car!
btw
Whats up with that 69 impala in the "Barn photo?" ...for sale??
MEXJOE is offline   Reply With Quote
