Old 03-14-2012, 06:38 AM   #9
dartman
dartman's Avatar
Liked 68 Times in 41 Posts
Default Re: Project update
Car look's great ,but where does it say you can use that rear end cover.as it not stock and also not in NHRA Accepted Products list. clearly state that it has a performance advantage.
High tensile aluminum alloy
Eliminates case distortion
Controls unwanted gear deflection
Provides additional clearance for low gear ratios
Allows aftermarket main caps and main cap stud kit installation
Increases fluid capacity
Reduces operating temperatures
Correct mounting fasteners included
Step-by-step instructions for a simple bolt-on installation
Originally Posted by Paul Merolla View Post
Don't see much of this type of post on classracer, but I enjoy seeing them on other boards I frequent, so here goes. Project is a 66 Nova...327/275 stick combo...bought it in '02 out of a barn:
Tore it apart, hung new quarter skins...then made a little room for tires:
Blasted the underside...made subframe connectors...installed rollbar:
That was all by the end of '03. Slacked on the car, got divorced, moved, etc. etc.
Fast forward to this fall...epoxy primed the underside, POR-15 on the floor and trunk, assembled rearend (thanks, Larry!) and as of last night, it's off the rotisserie!!
1231 FS/D Drag Pak
1231 E/SA 71 Demon
Kelly MacKay
dartman is offline   Reply With Quote
