Old 08-08-2012, 02:12 PM   #1
Straightliner
Default Re: .000 Timer??
Thank you, I will experiment with that.
Straightliner is offline   Reply With Quote
Old 08-08-2012, 02:50 PM   #2
GaryGoFast
Talking Re: .000 Timer??
The closer to the starting line you can go on the stop will maximize your mph ability.
Most stops will not close fast enough to not allow you to clear the tree. I have a 2835 lb S/St car that with first # @ .005 will go 147-149. With first # @ .000 I go 151-153. simply a longer run to finish li\ne allows you a few extra rpm. My .02
Gary Federico
S/St, S/G 1814
GaryGoFast is offline   Reply With Quote
