Old 09-15-2012, 01:37 AM   #7
Rick Bailey
Rick Bailey's Avatar
Liked 10 Times in 7 Posts
Default Re: Timer 2 calculation
Yes , as RR said I can do the same for you.
I also would like to know what your stop rpm is, this is where the big ratio number may be coming from, again depending on your combo this number will be in the range of 3800 - 4400
the math is , a standard equation, ratio number x et change, however you must have the correct ratio.
Then your next step is change in the air .... but we'll go one step at a time
Rick
Rick Bailey 3439 SC
Rick Bailey is offline   Reply With Quote
