Go Back   CLASS RACER FORUM > Class Racer Tech > Garage Tech
Old 12-11-2012, 10:47 AM   #1
Jeff Teuton
Liked 325 Times in 50 Posts
Default Re: floor paint/epoxy
We are currently redoing our race car facility completely. If you have raw cement, clean, etch, and apply epoxy. We use Carboline brand. Many colors, splatter available, add walnut shells for traction, and we are going to clear the Mopar Blue color for the floors. If you have an epoxy that is down (or some other hard coat), use a commercial sander and grind the top, clean and apply the epoxy. On raw cement, the etching is very important. Doesn't take long, just use a hand sprayer and wash. The floors we are redoing are 17 years old, and have had lots of abuse. In our dyno building, the floors are 14 years old and not subject to much abuse. Building is mostly closed, little or no traffic (human or car) and the floors still look excellent and need nothing, except for my desire for Mopar Blue floors with big "M's" in them. Carboline is a commercial coating and probably a little more expensive, but is really hard. The commercial floor grinder we rented was no match for the 17 year old stuff.
Jeff Teuton 4022 STK
Old 12-11-2012, 01:53 PM   #2
Bob Mulry
Bob Mulry's Avatar
Liked 320 Times in 102 Posts
Hi,
Years ago I bought a new house with a 3-car garage.....
The concrete had never been driven on and I used Thompson Water Seal on the floor....
I put it on with a mop as heavy as I could, waited for it to soak in and put down another coat...
I did that 3 or 4 times and used that garage for 7 years.....
The floor held up to everything but brake cleaner.....
Oil and solvent cleaned up with a mop......
No chipping from jacks or jack stands either......
Bob
Bob Mulry 7516 STK
A & M Motorsports
Old 12-13-2012, 07:06 PM   #3
Jim Johnston/6022
Liked 13 Times in 6 Posts
I used Behr 1-part epoxy concrete & garage floor paint 4years ago and the only thing that will not clean up is dye from racing gas. I have a friend that paints for a living-he has given up on so called industrial floor paints and uses this stuff on everthing. The big thing is it is water based and you do not need to mess with acid.
Jim Johnston/6022 is offline   Reply With Quote
Old 12-14-2012, 07:07 PM   #4
Greg Hill
Liked 279 Times in 68 Posts
I used ppg commercial epoxy floor coating. It's been fine I would do it in a much darker color though. Mine is light beige and it shows every speck of dirt or grease.
Greg Hill 4171 STK
