Old 02-02-2013, 01:55 PM   #1
rognelson777
Liked 135 Times in 74 Posts
Default GM 4l80e trans vibration in O/D when towing
Towing with a 1998 motorhome, has 7.4l chevy towing a 28ft champion trailer. When cruising at 65 mph on flat ground all is well, as soon as we hit grade, vibration starts, feels like the converter cannot decide to unlock or trans wants to downshift. If I depress gas pedal to full throttle it will downshift and vibration stops, then it seams to upshift but not lock up converter, when back to level ground converter locks up and all is well. no other trans issues. Motorhome has 58,000 miles.
Been researching options, 1 is to upgrade converter to TCI/hughes/B&M
2 is to rebuild trans.
3 Fast has a tuner / transmission re calibration programmer that will change transmission settings.
also thinking off upgrading exhaust for a little more horsepower and torque.
If all of the above is necessary, then may be time to upgrade motorhome to newer model or diesel.
Any recommendations ?
rognelson777 is offline   Reply With Quote
