Old 03-05-2013, 12:04 AM   #1
Rory Christianson
Liked 9 Times in 6 Posts
Default Re: Project 69 Corvette L88
Just a picture of putting on the hoist to finish stripping the pces off the body steering column, back end wiring, ac/heater housing, wipers and motor, master cylinder , pedals, etc., and getting ready to scrape off the underneath the car and remove some poorly repaired fibreglass in the floor areas.
Sorry I don't know how to attach more than one picture at a time, need to get that figured out, when I attach two the 2nd one just replaces the first one
Rory Christianson is offline   Reply With Quote
Old 03-05-2013, 12:11 AM   #2
Rory Christianson
Anyway one more picture on the hoist, will leave the posts until I figure out how to do the pictures better
Old 05-04-2013, 11:57 PM   #3
zedrone
What rear suspension are you going to use? IRS or Solid axle
zedrone is offline   Reply With Quote
Old 05-05-2013, 10:06 AM   #4
Rory Christianson
Hi
Solid axle
Old 05-30-2013, 10:16 PM   #5
Chad Rhodes
Originally Posted by Rory Christianson View Post
Hi
Solid axle
Why?
Chad Rhodes 2113 I/SA
Old 05-31-2013, 10:12 AM   #6
Fred Lee
Before you finalize your decision on the rear end please contact other Big Block Corvette racers that have successfully used an upgraded I.R.S. I have made an
Aluminum 12 bolt I.R.S. casting called the HammerHead for the 2010 Camaro that has been in several test cars with 800 plus hp. I am currently in the process of doing the same for the Challenger, Viper and C4 Corvette I.R.S.
If there is enough interest I can make a cast iron version of the 12 bolt HammerHead for the 63-79 Corvette also. NHRA will not allow an Aluminum replacement differential casting. If you are curious please visit hammerhousing.com for more info. Thank you
Fred Lee 231-740-5534 Cell phone
Fred Lee is offline   Reply With Quote
Old 06-02-2013, 10:59 AM   #7
Rory Christianson
Hi
Looks like a great pce.
I may be wrong but it has been my thoughts and understanding that the IRS may use up some hp and with my build of course I am only looking at point a to b in a straight line no corners, having said that thou may be there is a advantage to IRS on a rougher or uneven tracks ?
Are any of your units being used in the copo's in stock eliminator ?
I thought the factory ones came with a 9 inch ? Unless somebody was scratch building one
What are you thoughts on the hp drain from straight tube to IRS
Thanks Rory
