Liked 336 Times in 183 Posts
should-- but better off to check--- also look in the fenderwell see how much space there is--- some trailers have more space in front of and behind the tire(that is from the front of the trailer to towards the rear)--- some trailers only have maybe a inch others more---ya dont want the tire rubbing on the fenderwells--- if you get say a 225/75r/15 tire and replace it with a 225/75r/16 tire you only pick up about a 1/2 inch on the radius but if you put on say a 245/75r/16 tire ya might pick up as much as a inch so clearance is critical also check the width of the fenderwell too---trailer wheels usually are centered that means 0" back spacing or off set from the center of the wheel
Liked 56 Times in 29 Posts
My 24' has 15" wheels and 225-75-15 D rated tires. Each tire is rated 2500 lb, and the loaded trailer weighs 7000-7500 lb. I run the tires at 65 lb and haven't had trouble. I figured that if 16" trailer tires were the same chinesium, I wouldn't gain much since they aren't overloaded or close to it. Back in 2006 Goodyear published a bulletin saying if you go over 65, up to 75 mph, add 10 psi over what the load would require. They didn't say if you were at max load that you could add another 10 = 75 psi. Since I am well below max, I just run them at 65. It is very easy to add more weight than you think, and overload one or more tires. It is also easy to run too fast on a long trip. I'd say if you are close to max, 10,000 lb, then you would be pushing it to use 15" D tires. E tires might help, but you have also maxed out the axles. If your trailer is over 10,000 gvw, in some states you will need a CDL.
#3 | |
Guest
Posts: n/a
If you decide to run the 15" tires, do yourself a favor and a little insurance to last those nasty Texas summer heat on the roadways; change the rubber valve stems to the steel valve stems. The heat generated by the friction of the tires and the roads have caused rapid deterioration and cause tire failure as well.
FWIW, I had the 3500 axle and typical 15" tire and wheel combo. I went through 2-4 tires a year, irregardless of their age. I always carried 2 spares with me - and have used both on trips before. Ended up selling that trailer and bought a 28' 5200 lb axles with a 6 lug 15" wheel combo. Sold those wheels and put a set of 16" aluminum wheels and LT 245/16 without ANY issues over the last few years. |
#5 | |
Guest
Posts: n/a
If you look around you might be able to find a D or E load range LT ruck tire in the 15 inch size----WATCH YOUR AIR PRESSURE keep em inflated to max all the time --- regardless what you might hear from other racers DO NOT drive over about 60 MPH or you're gonna have blowouts
Liked 282 Times in 103 Posts
I have a Haulmark 24 ft enclosed trailer with tools,extra trans,scooter,and a bunch of other crap and haul a 1970 442 convertible (not a light car) and maybe had ONE flat tire in about 7 years.Must be lucky I guess.I have been known to exceed 60 mph on occasion.lol
15 inch load range D 225-75-15 tires |
Liked 373 Times in 131 Posts
I found some E rated 225-75-15's trailer tires last year. I didn't even know they existed until I saw them.
Best investment yet for my trailer. I love the way the tires stand straight up....none of that bow-out at the bottom like a radial.
Alan Mackin Stock 3777/ SS 3377 P/SA & SS/PA Fox Thunderbird I/PS '95 Mustang GT Last edited by ALMACK; 06-06-2013 at 02:26 PM. |
