What rear suspension are you going to use? IRS or Solid axle
Liked 9 Times in 6 Posts
Hi
Solid axle |
Chad Rhodes 2113 I/SA |
Before you finalize your decision on the rear end please contact other Big Block Corvette racers that have successfully used an upgraded I.R.S. I have made an
Aluminum 12 bolt I.R.S. casting called the HammerHead for the 2010 Camaro that has been in several test cars with 800 plus hp. I am currently in the process of doing the same for the Challenger, Viper and C4 Corvette I.R.S. If there is enough interest I can make a cast iron version of the 12 bolt HammerHead for the 63-79 Corvette also. NHRA will not allow an Aluminum replacement differential casting. If you are curious please visit hammerhousing.com for more info. Thank you Fred Lee 231-740-5534 Cell phone |
Hi
Looks like a great pce. I may be wrong but it has been my thoughts and understanding that the IRS may use up some hp and with my build of course I am only looking at point a to b in a straight line no corners, having said that thou may be there is a advantage to IRS on a rougher or uneven tracks ? Are any of your units being used in the copo's in stock eliminator ? I thought the factory ones came with a 9 inch ? Unless somebody was scratch building one What are you thoughts on the hp drain from straight tube to IRS Thanks Rory |
Rory,
All COPO Camaros and DragPak Challengers do use Strange engineered and NHRA accepted 9 inch Ford straight axles similar to the Cobra Jet Mustangs. The 12 bolt HammerHead I.R.S. that I make will be legal in Gen 5 Camaros that are in the NHRA stock car classification guide but it is not used under any COPO Camaros. Big Block Corvettes were known for breaking the weak factory I.R.S. rear ends but Tom's Differentials has developed many parts that will last. My goal was to make a 12 bolt aftermarket casting that will accept the 9310 alloy gears in all the popular ratios, 35 or 40 spline spools and whatever other heavy duty driveline parts that are currently available. I have not tested the power loss between a "straight axle" and an I.R.S. but the first test car for my 12 bolt I.R.S. was also the first test car for the Driveshaft Shop's 9 inch Ford fabricated I.R.S. We used a chassis dyno to compare the power loss at the rear wheels. The horsepower numbers were 780 for the 9 inch Ford and 800 for my 12 bolt. It has always been rumored that 12 bolt made 3% more power than the 9 inch Ford because the pinion is 3/4 of an inch further away from the ring gear centerline than the 12 bolt. (1.50 vs 2.25 inch) I do remember seeing 12 bolts installed under SSA/A Hemi cars to replace the Dana 60 also. Fred Lee |
Fred, what is the website again? www.hammerhousing.com doesnt seem to be working for me. need challenger info
#8 | |
Rory,
I was a Patternmaker for the foundry business for 40 years, so I am responsible for idea, design and manufacturing of the actual casting only. The price on my machined casting of about $1200. - $1500. is based on the low volume early Corvette market. The entire bolt-in kit requires Aftermarket stub axles, half shafts, etc. which will need to be purchased from a specialty company like Tom's Differentials. In the case of the Gen 5 Camaro 12 bolt kit, The Driveshaft Shop in Salisbury, NC makes those parts for the kit which retails for $5495. with driveshaft, stub axles, outer CV axles and choice of gears. Fred Lee |
