#11 |
Liked 31 Times in 19 Posts
Bob
So you want to install a Hemi in a A body using factory mounts?????. Your a brave man Hope you have alot of patience, specially if your using box headers (Hooker/TTI etc.). If you want to use an external oil pickup system, stay with a single line, because a dual line is ALMOST not doable without doing alot of cutting OR fabricating of mounts, & creating a new pickup port in the pump body because the "as delivered" ports will now allow for that second line. As your probably aware Hurst/Chrysler utized the welded steel mounts on the K member from Hemi B Bodies to build the original Hemi A cars.The rubber insulators were also used. The tubes they used were Hooker 2" & were delivered with a street hemi pan. This combination worked as is but did not allow for the oiling required for a high winding Hemi. So, the cutting started on both the drivers side mount & steering box mount. Now getting back on track to your install, the easiest will no doubt be an engine plate with a torque restrictor to limit fore & aft. movement.This will allow for dual external oiling & lots of header clearance If your interested in this next option, pm me & I'll give you the name/number of a buddy who fabricates 2 different Hemi A body K members as complete bolt in kits utilizing original style mounts, original K members & suspension . The first one he designed a few years back that locates the engine a little lower than stock, which allows for much needed trans tunnel/ header clearance. This K member will accomodate box headers. You'll have to ask him about 2 1/8" tho. I believe it'll only work with a single feed external oil system. The other K member he has available is a direct replacement of the originals, location wise. I know that because he borrowed my original to build his jig. My Hemi install is a little unique as I'm using an unmodified original style K member with custom built headers, custom fabbed engine mount made from DOM 1 3/4" tubing & a modified Milodon dual oiling system. MANY, MANY hours were spent making this work & all clearances for everything in that area are minimal. 1/16" is the difference of something fitting or interfering. This is the passenger side mount ![]() This is the drivers side mount ![]() If you closely you can see the new oil location at the bottom of the pump. The original 2 rear pickup locations remain plugged ![]() ![]() This is the almost ready to install assembly. Tubes are custom made . 2 1/8" primaries, 4" collectors. Passenger side is 2 piece, Drivers side is 5 piece. I need to remove both torsion bars, both tie rod assemblies, center link, have no starter or even the drain plg in the block to get them in. I can't even have the header gasket glued to the head for install, because the thickness of that gasket won't allow #1 tube to go in, even with the engine lifted. The gasket needs to be slipped in after the headers installed. ![]() have I scared you yet? They're not all this tight. I sold Dave McDade an original unmodified Hemi A Body K member & he installed it with the motor attached from the bottom. He dropped the body over the assembly. Valve covers were off tho. I don't believe he has an external oil system & I think his tubes are 2". Feel free to ask whatever you need to get that elfunt installed, & I'll do what I can to help you out. liteweight Last edited by Liteweight; 05-22-2013 at 03:51 PM. |
