Old 06-11-2013, 12:31 PM   #1
C and W Racing
C and W Racing's Avatar
Liked 13 Times in 3 Posts
Default Re: Going onto the stop question
The rpm that your car likes on the stop is dependent on a lot of things, signal thru the carb, heads, cam, converter, etc. That being said, I would raise the rpm's up 100 at a time until it finds the spot that it likes. Once you find that, you could maybe pull 50 rpm's back out if you are wanting to reduce the time that you are on the stop.
Chuck
C and W Racing is offline   Reply With Quote
