Liked 13 Times in 3 Posts
If it was my car, I would change the gear. I'm assuming you are running a small block with that much gear. In my super gas car, I run a 4.10 and have been thinking of trying a 3.89
Chuck |
Liked 20 Times in 9 Posts
It is a ford v-6 that i have been running in superstreet a little at 2450 lbs.,but i have been running the 5.67 gear and was just wondering if the trend is to get the mph up as much as possible and still keep the engine in are above peak hp.Thanks
I run a Hoosier 33.5/17-16 co7 compound
Chuck |
Liked 6 Times in 5 Posts
a 6cyl.runs 10.90 at s/st weight ?
yep as low as 2000 lbs and it can run 10.08 130 mph wide open.
Liked 880 Times in 311 Posts
Yep a V-6 can run fast. All it takes is HP.
It is not Super Street and it is a little heavier than 2,000 lbs and it is limited to a 750 carb. [ame="http://www.youtube.com/watch?v=eZPI6eCN8pE"]968et143mph - YouTube[/ame] The rear gear is: 6.33 In SS/DS it runs @ 3200 lbs
Adger Smith (Former SS) Last edited by Adger Smith; 08-09-2013 at 09:04 PM. Reason: sp |
The sweet sound of a v-6 making power,to bad they do'nt make any more parts for them.What kind of power are you making and at what rpm.With a 750 carb. and 6.33 gear must be pretty high.
