Go Back   CLASS RACER FORUM > Class Racer Tech > Garage Tech
Old 08-22-2013, 03:21 PM   #1
Rob Petrie E395
Liked 216 Times in 77 Posts
Default Re: Garage floor drains
What I did is I poured the floors flat but I put a trough near the bay doors and I squeegee the water to them. I also put a trough at the end of the apron out front to direct the runoff away from the driveway. The discharge runs into my yard with no problems in the last 10 years. But I do not wash out oil based products.. Best thing I did for the floor was when I put a epoxy coating on it to make it easier to clean. Lowes sells the grates that I used on top to of the troughs to keep the floor smooth and not have to bounce over the trough when driving in and out.
Old 09-05-2013, 07:46 AM   #2
Pedigo Perf
Pedigo Perf's Avatar
Liked 30 Times in 17 Posts
In my auto repair shops we have to use a pre-fab concrete vault about 5' by 10' by 4' deep installed in the ground that has a divider wall cast into it for the separator. They are commercially available through most plumbing supply companies that do septic systems I think. This is an added expense, potential source of an unpleasant odor, and additional maintenance for you. We generally clean up with a mop as my floors are smooth and don't even use the drains.
Have your builder/concrete guy put a slight slope to the overhead door for slush and car wash water to keep it from going under the benches and shelves. I would just forget the drain unless you plan on running water on the floor dailey.
Sounds like a great project to be doing, hope it becomes your dream garage.
Tracy
Pedigo Perf is offline   Reply With Quote
Old 09-05-2013, 01:39 PM   #3
Sean Marconette
Sean Marconette's Avatar
Liked 275 Times in 76 Posts
Thanks for all of the responses! It was a busy and exhausting time with getting the rough in done with the weather that we have had here. Trenching for power, water and the plumbing to the septic tank was almost too much. I decided to eliminate the floor drains, more out of exhaustion and almost heat stroke than anything. Everything passed with flying colors and the building slab was poured last Wedensday. The slab is a slick finish, so cleanup will be easy. The concrete crew is finishing the driveway tomorrow.
Taking others advice from another thread, I have installed a floor sink in the building where the trailer will be parked to dump the tanks from the trailer. I can't wait to use that instead of dealing with dumping at rest stops or trying to find a place after a long weekend at the track.
Thanks
Sean
Sean Marconette
84 Mustang
5060 SS/N
Old 09-20-2013, 12:35 PM   #4
tj310
We got our floor poured this week (hope the pictures show up) put the drain in myself , might be too big --- Trevor
ID:	21507   Click image for larger version
ID:	21508   Click image for larger version
