Go Back   CLASS RACER FORUM > Class Racer Tech > Garage Tech
Old 08-22-2013, 03:24 PM   #1
Rob Petrie E395
Liked 216 Times in 77 Posts
Default Re: floor paint/epoxy
On my last house I used the Rustolium brand stuff and put the chips in it. I found it was very hard to sweep and get all the dust out. On my current home and shop I used rustolium again but did not put the chips in it and it is alot smoother and easier to keep clean. Current floors were done 10 years ago and other than a few chips here and there from dropping stuff they are fine except for some very light fading near the doors and windows.
Old 08-22-2013, 08:55 PM   #2
Ronnie Smith Jr
Ronnie Smith Jr's Avatar
I just completed a garage renovation over Memorial Day weekend. I used Shield Crete from Sherwin Williams. I researched online for sometime and it boiled down to 3 brands - Shield Crete, Armor Coating and U-Coat It. Based on my online searches, I felt that all three brands were relatively the same. At the time, Sherwin Williams was having a 40% off sale which is what put them over the edge. I cannot stress enough on the prep work prior to laying down the epoxy. I did not like the outcome the cleaner/degreaser so I rented a concrete grinder so I could ensure getting all of the stains from oil, grime and petroleum products that leached out of tires into the concrete for 26 years would come out. After I took about a 1/64th of an inch off the top, I power washed the garage out and then acid etched it, and then power washed it out 3 times. Layed down the epoxy (beige) and added the chips. After it set for about 30 hours, I layed down 2 coats of sealer on top. I then let it cure for 6 days before I rolled the cars in. The directions state to allow 72 hours though. I just wanted to make sure. So far so good. None of it has peeled up. I am having tire staining issues though and cannot seem to scrub enough to remove the stains. I have used Simple Green, Spray 9, Castrol Super Cleaner and Mr Clean Magic Eraser. Any advice? As soon as I get the stains up I will be putting down some type of rug or device so the tires can no longer stain the floor.
Thanks
Ronnie Smith Jr is offline   Reply With Quote
