Old 09-10-2007, 11:25 AM   #7
Dave Goob Cook
Dave Goob Cook's Avatar
Default Re: front suspension ?
When you re-bush the front arms, grind the "teeth" off the inner bushing and don't tighten the bolts on the lowers to the point they grip the inner bushing, that way you'll get no "loading" of the rubber bushings in the travel, if you prefer to stay with an O.E. rubber or urethane type bushings.....I've found that the O.E. rubber bushings are actually more durable in the rear than the urethanes I wasted $$$ on......I now use a 3 piece deal on the rears from a place called HR PartsnStuff, best ones I've had in there so far, not sure if they offer anything for the fronts or not.
Dave Goob Cook is offline   Reply With Quote
